Logo
View unanswered posts | View active topics It is currently Sun May 19, 2013 4:21 am
Reply to topic  [ 6 posts ]
Turn signal indicator always on...
Author Message
Post Turn signal indicator always on...
Hey guys, I have a 78 P200E (VSX1T USA before 1979 schematic ) and here are the weird symptoms:
Indicator light is always on if I use turn signal it does blink from on to off and on, but the light looks more intense, after some riding and revving the bulb dies.
The horn sounds like crap, like a small bark and nothing more even if you leave the button on.
The speedo light also died ( not sure if its related )
The front and back light are Ok and are not always they are Ok.
This happened ones long time ago and I think that beside changing the bulbs the flasher was too.
I haven't changed bulbs flasher this time around I used the neutral one to test the indicator issue, wiring looks good no shorts or issues on the headset junction boxes on the motor or on the horn side, or the flasher/regulator.
Even if I disconnect the P connector on the flasher ( or all 3 connector on the flasher ) the horn still sounds like crap.
Could the Regulator be killing the flasher and the bulbs after wards?, I didn't check the voltage that the indicator bulb has when its the most intense.
Any suggestions??
The Romantic Hispanic
Mon Jul 16, 2012 11:55 am
Profile
Post Re: Turn signal indicator always on...
Dead creature under your left handlebar switch.
_________________
Friends do not let friends buy product from the shitbags at ScootRS
Mon Jul 16, 2012 1:10 pm
Profile WWW
And a barking one for that matter...
Mon Jul 16, 2012 1:19 pm
Profile
I had pretty much all these symptoms (1980 P200)
Charge or replace the battery.
Worked for me.
Mon Jul 16, 2012 3:20 pm
Profile
battery is low / can't hold a charge above the min needed for the blinker relay
check
- battery health
- battery liquid = if the metal plates within the battery have been exposed to air = it will never hold a greater charge than it is now = get new battery
you can put a battery tender onto the battery wires and test the scoots electrical system with engine off
if all works great = battery is the issue
when my battery would die the 1st thing to go was the horn, then the blinkers and then the rear light
_________________
ww
Mon Jul 16, 2012 4:50 pm
Profile
Guys,
Here is the update!
I did replace the battery and damaged bulbs ( also the back light was dead ) , the horn worked fine now but the indicator light still was always on, I replaced the flasher and it works fine now.
Thanks
Oscar
Mon Jul 23, 2012 1:21 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by ST Software for PTF.
